Add Script dialog box
PDF of this doc site
- Online Help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
Your file is ready
The Add Script dialog box enables you to add scripts to Unified Manager. You can configure alerts with your scripts to automatically resolve events that are generated for storage objects.
You must have the Application Administrator or Storage Administrator role.
Select Script File
Enables you to select a script for the alert.
Enables you to specify a description for the script.
