Annotate Cluster dialog box
PDF of this doc site
- Online Help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
Your file is ready
The Annotate Cluster dialog box enables you to manually annotate storage objects. You can select either a single cluster or multiple clusters and annotate with a specific value pair from the existing list of annotations.
You must have the Application Administrator or Storage Administrator role.
Annotation=Value Pairs
Enables you to select the required annotation for the selected cluster.
Apply
Applies the selected annotation to the cluster.
Cancel
Closes the Annotate Cluster dialog box without saving your changes.
