Active IQ Unified Manager 9.8
9.8
Add Group Rule dialog box
The Add Group Rule dialog box enables you to create group rules in Unified Manager to dynamically group storage objects. You can later configure and apply group actions for the group.
You must have the Application Administrator or Storage Administrator role.
  • Name
    Specifies the name of the group rule.
  • Target Object Type
    Specifies the type of storage objects to include in the group.
  • Group
    Specifies the name of the group for which the group rule is created.
  • Conditions
    Specifies conditions that determine which storage objects can be included in a group.
  • Condition group
    Specifies condition groups which have one or more conditions defined for including storage objects in a group.
Command buttons
  • Save and Add
    Adds the group rule and enables you to add another group rule without closing the dialog box.
  • Add
    Adds the group rule and closes the Add Group Rule dialog box.
  • Cancel
    Cancels the changes and closes the Add Group Rule dialog box.
  • Add Condition
    Adds a condition to define the group rule.
  • Add Condition Group
    Adds a condition group to define conditions for the group rule.
