Active IQ Unified Manager 9.8
9.8
Annotate Cluster dialog box
The Annotate Cluster dialog box enables you to manually annotate storage objects. You can select either a single cluster or multiple clusters and annotate with a specific value pair from the existing list of annotations.
You must have the Application Administrator or Storage Administrator role.
  • Annotation=Value Pairs
    Enables you to select the required annotation for the selected cluster.
  • Apply
    Applies the selected annotation to the cluster.
  • Cancel
    Closes the Annotate Cluster dialog box without saving your changes.
