Digital Advisor
Renew your support contracts
Contributors netapp-manishc netapp-reenu
You can view the score and summary of all the active support contracts on the dashboard. You can take actions based on the key recommendations which are provided in order of priority.
Steps
  1. On the Health Check Dashboard, click the Support & Entitlements widget.
  2. If any of your system support contracts have expired or are nearing expiration, then click the Active Support Contracts widget.
  3. Select the checkboxes and click Renew for initiating the renewal process for the selected systems.
