BlueXP backup and recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Restore MongoDB, MySQL, and PostgreSQL databases
Contributors netapp-soumikd
You can restore MongoDB, MySQL, and PostgreSQL databases to any host.
Steps
  1. In BlueXP UI, click Protection > Backup and recovery > Applications.
  2. In the Filter By field, select the filter Type and from the drop-down select MongoDB, MySQL, or PostgreSQL.
  3. Click View Details corresponding to the database that you want to restore and click Restore.
  4. In the Restore options page, specify one of the following:
    1. For NAS environment, specify the FQDN or IP address of the host to which the volumes restored from object store are to be exported.
    2. For SAN environment, specify the initiators of the host to which LUNs of the volumes restored from object store are to be mapped.
  5. If the snapshot is in archival storage, select the priority to restore your data from the archival storage.
  6. If there is not enough space on the source storage or the source storage is down, select Change storage location.
    If you select Change storage location, you can append a suffix to the destination volume. If you have not selected the checkbox, then by default _restore is appended to the destination volume.
  7. Click Next.
  8. In the Storage mapping page, specify the alternate storage location details where the data restored from the object store will be stored.
  9. Click Next.
  10. Review the details and click Restore.
This operation does only the storage export of the selected backup on the given host. You should manually mount the filesystem and bring up the database. After utilizing the volume, the storage Administrator can delete the volume from the ONTAP cluster.
