Supported ONTAP versions for Cloud Volumes ONTAP deployments
The NetApp Console enables you to choose from several different ONTAP versions when you add a Cloud Volumes ONTAP system.
Cloud Volumes ONTAP versions other than those listed here are not available for new deployments. The patch or the generic (General Availability) version in a release here represents the base version available for deployment. For details about the available patches, refer to the versioned release notes for each release.
For information on upgrade, refer to Supported upgrade paths.
AWS
- Single node
9.18.1
9.17.1 P1
9.16.1
9.15.1
9.15.0 P1
9.14.1
9.14.1
9.14.0
9.13.1
9.12.1
9.12.1
9.12.0 P1
9.11.1 P3
9.10.1
9.9.1 P6
9.8
9.7 P5
9.5 P6
- HA pair
9.18.1
9.17.1 P1
9.16.1
9.15.1
9.15.0 P1
9.14.1
9.14.1
9.14.0
9.13.1
9.12.1
9.12.1
9.12.0 P1
9.11.1 P3
9.10.1
9.9.1 P6
9.8
9.7 P5
9.5 P6
Azure
- Single node
9.18.1
9.17.1 P1
9.16.1 P3
9.15.1 P10
9.14.1 P13
9.13.1 P16
9.12.1 P18
- HA pair
9.18.1
9.17.1 P1
9.16.1 P3
9.15.1 P10
9.14.1 P13
9.13.1 P16
9.12.1 P18
Google Cloud
- Single node
9.18.1
9.17.1 P1
9.16.1
9.15.1
9.15.0 P1
9.14.1
9.14.1
9.14.0
9.13.1
9.12.1
9.12.1
9.12.0 P1
9.11.1 P3
9.10.1
9.9.1 P6
9.8
9.7 P5
- HA pair
9.18.1
9.17.1 P1
9.16.1
9.15.1
9.15.0 P1
9.14.1
9.14.1
9.14.0
9.13.1
9.12.1
9.12.1
9.12.0 P1
9.11.1 P3
9.10.1
9.9.1 P6
9.8
