Change the Google Cloud machine type for Cloud Volumes ONTAP
You can choose from several machine types when you launch Cloud Volumes ONTAP in Google Cloud. You can change the instance or machine type at any time if you determine that it is undersized or oversized for your needs.
Automatic giveback must be enabled on a Cloud Volumes ONTAP HA pair (this is the default setting). If it isn't, then the operation will fail.
Changing the machine type can affect Google Cloud service charges.
The operation restarts Cloud Volumes ONTAP.
For single-node systems, I/O is interrupted.
For HA pairs, the change is nondisruptive. HA pairs continue to serve data.
The NetApp Console changes one node at a time by initiating takeover and waiting for give back. NetApp's Quality Assurance team tested both writing and reading files during this process and didn't see any issues on the client side. As connections changed, some retries were observed on the I/O level, but the application layer overcame the rewiring of NFS/CIFS connections.
On the Systems page, select the system.
On the Overview tab, click the Features panel and then click the pencil icon next to Machine type.
If you are using a node-based pay-as-you-go (PAYGO) license, you can optionally choose a different license and machine type by clicking the pencil icon next to License type.
Choose an machine type, select the check box to confirm that you understand the implications of the change, and then click Change.
Cloud Volumes ONTAP reboots with the new configuration.
