Setup and administration
Learn about BlueXP deployment modes
Contributors netapp-bcammett
BlueXP offers multiple deployment modes that enable you to use BlueXP in a way that meets your business and security requirements. Standard mode leverages the BlueXP SaaS layer to provide full functionality, while restricted mode and private mode are available for organizations that have connectivity restrictions.
While BlueXP inhibits the flow of traffic, communication, and data when using restricted mode or private mode, it's your responsibility to ensure that your environment (on premises and in the cloud) is in compliance with the required regulations.
Overview
BlueXP offers the following deployment modes for your account. Each mode differs in terms of outbound connectivity requirements, deployment location, installation process, authentication method, available data and storage services, and charging methods.
Standard mode
BlueXP is accessible to users as a cloud service from the web-based console. Depending on the BlueXP services that you're planning to use, a BlueXP admin creates one or more Connectors to manage data within your hybrid cloud environment.
This mode uses encrypted data transmission over the public internet.
Restricted mode
A BlueXP Connector is installed in the cloud (in a government region, sovereign cloud region, or commercial region) and has limited outbound connectivity to the BlueXP SaaS layer. Users access BlueXP locally from the web-based console that's available from the Connector, not from the SaaS layer.
This mode is typically used by state and local governments and regulated companies.
Private mode
A BlueXP Connector is installed on premises or in the cloud (in a secure region, sovereign cloud region, or commercial region) and has no connectivity to the BlueXP SaaS layer. Users access BlueXP locally from the web-based console that's available from the Connector, not from the SaaS layer.
A secure region includes AWS Secret Cloud, AWS Top Secret Cloud, and Azure IL6
The following table provides a comparison of these modes.
Standard mode Restricted mode Private mode
Connection required to BlueXP SaaS layer?
Yes
Outbound only
No
Connection required to your cloud provider?
Yes
Yes, within the region
Yes, within the region (if using Cloud Volumes ONTAP)
Connector installation
From BlueXP, cloud marketplace, or manual install
Cloud marketplace or manual install
Manual install
Connector upgrades
Automatic upgrades of NetApp Connector software
Manual upgrade required
UI access
From the BlueXP SaaS layer
Locally from the Connector VM
API endpoint
The BlueXP SaaS layer
The Connector
The Connector
Authentication
Through SaaS using auth0, NSS login, or identity federation
Through SaaS using auth0 or identity federation
Local user authentication
Storage and data services
All are supported
Many are supported
Several are supported
Licensing options
Marketplace subscriptions and BYOL
BYOL
Read through the following sections to learn more about these modes, including which BlueXP features and services are supported.
Standard mode
The following image is an example of a standard mode deployment.
A conceptual image that shows the public internet where the web-based console, SaaS layer, and auth0 authentication are available, a virtual network in the cloud where a Connector is running and managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
BlueXP works as follows in standard mode:
Outbound communication
Connectivity is required from the Connector to the BlueXP SaaS layer, to your cloud provider's publicly available resources, and to other essential components for day-to-day operations.
Supported location for the Connector
In standard mode, the Connector is supported in the cloud or on your premises.
Connector installation is possible from a setup wizard in BlueXP, from the AWS or Azure Marketplace, or using an installer to manually install the Connector on your own Linux host in your data center or in the cloud.
Connector upgrades
Automated upgrades of the Connector software are available from BlueXP with monthly updates.
User interface access
The user interface is accessible from the web-based console that's provided through the SaaS layer.
API endpoint
API calls are made to the following endpoint:
https://cloudmanager.cloud.netapp.com
Authentication
Authentication is provided through BlueXP's cloud service using auth0 or through NetApp Support Site (NSS) logins. Identity federation is available.
Supported BlueXP services
All BlueXP services are available to users.
Supported licensing options
Marketplace subscriptions and BYOL are supported with standard mode; however, the supported licensing options depends on which BlueXP service you are using. Review the documentation for each service to learn more about the available licensing options.
How to get started with standard mode
Go to the BlueXP web-based console and sign up.
Restricted mode
The following image is an example of a restricted mode deployment.
A conceptual image that shows the public internet where the SaaS layer and auth0 authentication are available, a virtual network in the cloud where a Connector is running and providing access to the web-based console, and is managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
BlueXP works as follows in restricted mode:
Outbound connectivity is required from the Connector to the BlueXP SaaS layer to use BlueXP data services, to enable automatic software upgrades of the Connector, to use auth0-based authentication, and to send metadata for charging purposes (storage VM name, allocated capacity, and volume UUID, type, and IOPS).
The BlueXP SaaS layer does not initiate communication to the Connector. All communication is initiated by the Connector, which can pull or push data from or to the SaaS layer as required.
A connection is also required to cloud provider resources from within the region.
In restricted mode, the Connector is supported in the cloud: in a government region, sovereign region, or commercial region.
Connector installation is possible from the AWS or Azure Marketplace or a manual installation on your own Linux host.
Connector upgrades
The user interface is accessible from the Connector virtual machine that's deployed in your cloud region.
API endpoint
API calls are made to the Connector virtual machine.
Authentication
Authentication is provided through BlueXP's cloud service using auth0. Identity federation is also available.
BlueXP supports the following storage and data services with restricted mode:
Supported services Notes
Amazon FSx for ONTAP
Full support
Azure NetApp Files
Full support
Backup and recovery
Supported in Government regions and commercial regions with restricted mode. Not supported in sovereign regions with restricted mode.
In restricted mode, BlueXP backup and recovery supports back up and restore of ONTAP volume data only. View the list of supported backup destinations for ONTAP data
Back up and restore of application data, virtual machine data, and Kubernetes data is not supported.
Classification
Supported in Government regions with restricted mode. Not supported in commercial regions or in sovereign regions with restricted mode.
The following limitations apply:
  • OneDrive accounts, SharePoint accounts, and Google Drive accounts can't be scanned.
  • Microsoft Azure Information Protection (AIP) label functionality can't be integrated.
Cloud Volumes ONTAP
Full support
Digital wallet
You can use the digital wallet with the supported licensing options listed below for restricted mode.
On-premises ONTAP clusters
Discovery with a Connector and discovery without a Connector (direct discovery) are both supported.
When you discover an on-prem cluster with a Connector, the Advanced view (System Manager) is not supported.
Replication
The following licensing options are supported with restricted mode:
  • Marketplace subscriptions (hourly and annual contracts)
    Note the following:
    • For Cloud Volumes ONTAP, only capacity-based licensing is supported.
    • In Azure, annual contracts are not supported with government regions.
  • BYOL
    For Cloud Volumes ONTAP, both capacity-based licensing and node-based licensing are supported with BYOL.
How to get started with restricted mode
You need to enable restricted mode when you create your BlueXP account.
If you don't have an account yet, you'll be prompted to create your account and enable restricted mode when you log in to BlueXP for the first time from a Connector that you manually installed or that you created from your cloud provider's marketplace.
If you already have an account and you want to create another one, then you need to use the Tenancy API.
Note that you can't change the restricted mode setting after BlueXP creates the account. You can't enable restricted mode later and you can't disable it later. It must be set at time of account creation.
Private mode
In private mode, you can install a Connector either on premises or in the cloud and then use BlueXP to manage data across your hybrid cloud. There is no connectivity to the BlueXP SaaS layer.
The following image shows an example of a private mode deployment where the Connector is installed in the cloud and manages both Cloud Volumes ONTAP and an on-premises ONTAP cluster.
A conceptual image that shows a virtual network in the cloud where a Connector is running and providing access to the web-based console, and is managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
Meanwhile, the second image shows an example of a private mode deployment where the Connector is installed on premises, manages an on-premises ONTAP cluster, and provides access to supported BlueXP data services.
A conceptual image that shows an on-premises data center where a Connector is running and providing access to the web-based console, BlueXP data services, and is managing an AFF cluster in an on-premises data center.
BlueXP works as follows in private mode:
No outbound connectivity is required to the BlueXP SaaS layer. All packages, dependencies, and essential components are packaged with the Connector and served from the local machine. Connectivity to your cloud provider's publicly available resources is required only if you are deploying Cloud Volumes ONTAP.
In private mode, the Connector is supported in the cloud or on premises.
Manual installations of the Connector are supported on your own Linux host in the cloud or on premises.
Connector upgrades
You need to upgrade the Connector software manually. The Connector software is published to the NetApp Support Site at undefined intervals.
The user interface is accessible from the Connector that's deployed in your cloud region or on premises.
API endpoint
Authentication
Authentication is provided through local user management and access. Authentication is not provided through BlueXP's cloud service.
Supported BlueXP services in cloud deployments
BlueXP supports the following storage and data services with private mode when the Connector is installed in the cloud:
Backup and recovery
Supported in AWS and Azure commercial regions.
Not supported in Google Cloud or in AWS Secret Cloud, AWS Top Secret Cloud, or Azure IL6
In private mode, BlueXP backup and recovery supports back up and restore of ONTAP volume data only. View the list of supported backup destinations for ONTAP data
Cloud Volumes ONTAP
Because there's no internet access, the following features aren't available: automated software upgrades and AutoSupport.
Digital wallet
You can use the digital wallet with the supported licensing options listed below for private mode.
Requires connectivity from the cloud (where the Connector is installed) to the on-premises environment.
Discovery without a Connector (direct discovery) is not supported.
Supported BlueXP services in on-prem deployments
BlueXP supports the following storage and data services with private mode when the Connector is installed on your premises:
Backup and recovery
In private mode, BlueXP backup and recovery supports back up and restore of ONTAP volume data only. View the list of supported backup destinations for ONTAP volume data
Classification
Digital wallet
Replication
Full support
Only BYOL is supported with private mode.
For Cloud Volumes ONTAP BYOL, only node-based licensing is supported. Capacity-based licensing is not supported. Because an outbound internet connection isn't available, you will need to manually upload your Cloud Volumes ONTAP licensing file in the BlueXP digital wallet.
How to get started with private mode
Private mode is available by downloading the "offline" installer from the NetApp Support Site.
Note If you want to use BlueXP in the AWS Secret Cloud or the AWS Top Secret Cloud, then you should follow separate instructions to get started in those environments. Learn how to get started with Cloud Volumes ONTAP in the AWS Secret Cloud or Top Secret Cloud
Service and feature comparison
The following table can help you quickly identify which BlueXP services and features are supported with restricted mode and private mode.
Note that some services might be supported with limitations. For more details about how these services are supported with restricted mode and private mode, refer to the sections above.
Product area BlueXP service or feature Restricted mode Private mode
Working environments
This portion of the table lists support for working environment management from the BlueXP canvas. It does not indicate the supported backup destinations for BlueXP backup and recovery.
Yes
No
Amazon S3
No
No
Azure Blob
No
No
Azure NetApp Files
Yes
No
Cloud Volumes ONTAP
Yes
Yes
Cloud Volumes Service for Google Cloud
No
No
Google Cloud Storage
No
No
Kubernetes clusters
No
No
On-prem ONTAP clusters
Yes
Yes
E-Series
No
No
StorageGRID
No
No
Services
Backup and recovery
Yes
Yes
Classification
Yes
Yes
Cloud ops
No
No
Copy and sync
No
No
Digital advisor
No
No
Digital wallet
Yes
Yes
Disaster recovery
No
No
Economic efficiency
No
No
Edge caching
No
No
Migration reports
No
No
Operational resiliency
No
No
Ransomware protection
No
No
Replication
Yes
Yes
Sustainability
No
No
Tiering
No
No
Volume caching
No
No
Features
Credentials
Yes
Yes
NSS accounts
Yes
No
Notifications
Yes
No
Search
Yes
No
Timeline
Yes
Yes
