BlueXP setup and administration
Ports for the on-prem Connector
Contributors netapp-bcammett
The Connector uses inbound ports when installed manually on an on-premises Linux host. You might need to refer to these ports for planning purposes.
These inbound rules apply to all BlueXP deployment models.
Protocol Port Purpose
HTTP
80
  • Provides HTTP access from client web browsers to the local user interface
  • Used during the Cloud Volumes ONTAP upgrade process
HTTPS
443
Provides HTTPS access from client web browsers to the local user interface
