Create a Connector in AWS from BlueXP
To create a Connector in AWS from BlueXP, you need to set up your networking, prepare AWS permissions, and then create the Connector.
You should review Connector limitations.
Step 1: Set up networking
Ensure that the network location where you plan to install the Connector supports the following requirements. Meeting these requirements enables the Connector to manage resources and processes within your hybrid cloud environment.
- VPC and subnet
When you create the Connector, you need to specify the VPC and subnet where the Connector should reside.
- Connections to target networks
A Connector requires a network connection to the location where you're planning to create and manage working environments. For example, the network where you plan to create Cloud Volumes ONTAP systems or a storage system in your on-premises environment.
- Outbound internet access
The network location where you deploy the Connector must have an outbound internet connection to contact specific endpoints.
- Endpoints contacted from the Connector
The Connector requires outbound internet access to contact the following endpoints in order to manage resources and processes within your public cloud environment for day-to-day operations.
Note that the endpoints listed below are all CNAME entries.
Endpoints Purpose AWS services (amazonaws.com):
CloudFormation
Elastic Compute Cloud (EC2)
Identity and Access Management (IAM)
Key Management Service (KMS)
Security Token Service (STS)
Simple Storage Service (S3)
To manage resources in AWS. The exact endpoint depends on the AWS region that you're using. Refer to AWS documentation for details
https://support.netapp.com
https://mysupport.netapp.comTo obtain licensing information and to send AutoSupport messages to NetApp support.
https://*.api.bluexp.netapp.com
https://api.bluexp.netapp.com
https://*.cloudmanager.cloud.netapp.com
https://cloudmanager.cloud.netapp.com
https://netapp-cloud-account.auth0.com
To provide SaaS features and services within BlueXP.
Note that the Connector is currently contacting "cloudmanager.cloud.netapp.com" but it will start contacting "api.bluexp.netapp.com" in an upcoming release.
https://*.blob.core.windows.net
https://cloudmanagerinfraprod.azurecr.io
To upgrade the Connector and its Docker components.
- Endpoints contacted from the BlueXP console
As you use the BlueXP web-based console that's provided through the SaaS layer, it contacts several endpoints to complete data management tasks. This includes endpoints that are contacted to deploy the Connector from the BlueXP console.
- Proxy server
If your organization requires deployment of a proxy server for all outgoing internet traffic, obtain the following information about your HTTP or HTTPS proxy. You'll need to provide this information during installation.
IP address
Credentials
HTTPS certificate
Note that BlueXP does not support transparent proxy servers.
- Ports
There's no incoming traffic to the Connector, unless you initiate it or if the Connector is used as a proxy to send AutoSupport messages from Cloud Volumes ONTAP to NetApp Support.
HTTP (80) and HTTPS (443) provide access to the local UI, which you'll use in rare circumstances.
SSH (22) is only needed if you need to connect to the host for troubleshooting.
Inbound connections over port 3128 are required if you deploy Cloud Volumes ONTAP systems in a subnet where an outbound internet connection isn't available.
If Cloud Volumes ONTAP systems don't have an outbound internet connection to send AutoSupport messages, BlueXP automatically configures those systems to use a proxy server that's included with the Connector. The only requirement is to ensure that the Connector's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Connector.
- Enable NTP
If you're planning to use BlueXP classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the BlueXP Connector system and the BlueXP classification system so that the time is synchronized between the systems. Learn more about BlueXP classification
You'll need to implement this networking requirement after you create the Connector.
Step 2: Set up AWS permissions
BlueXP needs to authenticate with AWS before it can deploy the Connector instance in your VPC. You can choose one of these authentication methods:
Let BlueXP assume an IAM role that has the required permissions
Provide an AWS access key and secret key for an IAM user who has the required permissions
With either option, the first step is to create an IAM policy. This policy contains only the permissions needed to launch the Connector instance in AWS from BlueXP.
If needed, you can restrict the IAM policy by using the IAM Condition
element. AWS documentation: Condition element
When BlueXP creates the Connector, it applies a new set of permissions to the Connector instance that enables the Connector to manage AWS resources. |
Go to the AWS IAM console.
Select Policies > Create policy.
Select JSON.
Copy and paste the following policy:
As a reminder, this policy contains only the permissions needed to launch the Connector instance in AWS from BlueXP. View permissions required for the Connector instance itself.
{ "Version": "2012-10-17", "Statement": [ { "Effect": "Allow", "Action": [ "iam:CreateRole", "iam:DeleteRole", "iam:PutRolePolicy", "iam:CreateInstanceProfile", "iam:DeleteRolePolicy", "iam:AddRoleToInstanceProfile", "iam:RemoveRoleFromInstanceProfile", "iam:DeleteInstanceProfile", "iam:PassRole", "iam:ListRoles", "ec2:DescribeInstanceStatus", "ec2:RunInstances", "ec2:ModifyInstanceAttribute", "ec2:CreateSecurityGroup", "ec2:DeleteSecurityGroup", "ec2:DescribeSecurityGroups", "ec2:RevokeSecurityGroupEgress", "ec2:AuthorizeSecurityGroupEgress", "ec2:AuthorizeSecurityGroupIngress", "ec2:RevokeSecurityGroupIngress", "ec2:CreateNetworkInterface", "ec2:DescribeNetworkInterfaces", "ec2:DeleteNetworkInterface", "ec2:ModifyNetworkInterfaceAttribute", "ec2:DescribeSubnets", "ec2:DescribeVpcs", "ec2:DescribeDhcpOptions", "ec2:DescribeKeyPairs", "ec2:DescribeRegions", "ec2:DescribeInstances", "ec2:CreateTags", "ec2:DescribeImages", "ec2:DescribeAvailabilityZones", "ec2:DescribeLaunchTemplates", "ec2:CreateLaunchTemplate", "cloudformation:CreateStack", "cloudformation:DeleteStack", "cloudformation:DescribeStacks", "cloudformation:DescribeStackEvents", "cloudformation:ValidateTemplate", "ec2:AssociateIamInstanceProfile", "ec2:DescribeIamInstanceProfileAssociations", "ec2:DisassociateIamInstanceProfile", "iam:GetRole", "iam:TagRole", "kms:ListAliases", "cloudformation:ListStacks" ], "Resource": "*" }, { "Effect": "Allow", "Action": [ "ec2:TerminateInstances" ], "Condition": { "StringLike": { "ec2:ResourceTag/OCCMInstance": "*" } }, "Resource": [ "arn:aws:ec2:*:*:instance/*" ] } ] }
Select Next and add tags, if needed.
Select Next and enter a name and description.
Select Create policy.
Either attach the policy to an IAM role that BlueXP can assume or to an IAM user so that you can provide BlueXP with access keys:
(Option 1) Set up an IAM role that BlueXP can assume:
Go to the AWS IAM console in the target account.
Under Access Management, select Roles > Create Role and follow the steps to create the role.
Under Trusted entity type, select AWS account.
Select Another AWS account and enter the ID of the BlueXP SaaS account: 952013314444
Select the policy that you created in the previous section.
After you create the role, copy the Role ARN so that you can paste it in BlueXP when you create the Connector.
(Option 2) Set up permissions for an IAM user so that you can provide BlueXP with access keys:
From the AWS IAM console, select Users and then select the user name.
Select Add permissions > Attach existing policies directly.
Select the policy that you created.
Select Next and then select Add permissions.
Ensure that you have the access key and secret key for the IAM user.
You should now have an IAM role that has the required permissions or an IAM user that has the required permissions. When you create the Connector from BlueXP, you can provide information about the role or access keys.
Step 3: Create the Connector
Create the Connector directly from the BlueXP web-based console.
Creating the Connector from BlueXP deploys an EC2 instance in AWS using a default configuration. After you create the Connector, you should not change to a smaller EC2 instance type that has less CPU or RAM. Learn about the default configuration for the Connector.
You should have the following:
An AWS authentication method: either an IAM role or access keys for an IAM user with the required permissions.
A VPC and subnet that meets networking requirements.
A key pair for the EC2 instance.
Details about a proxy server, if a proxy is required for internet access from the Connector.
Select the Connector drop-down and select Add Connector.
Choose Amazon Web Services as your cloud provider and select Continue.
On the Deploying a Connector page, review the details about what you'll need. You have two options:
Select Continue to prepare for deployment by using the in-product guide. Each step in the in-product guide includes the information that's contained on this page of the documentation.
Select Skip to Deployment if you already prepared by following the steps on this page.
Follow the steps in the wizard to create the Connector:
Get Ready: Review what you'll need.
AWS Credentials: Specify your AWS region and then choose an authentication method, which is either an IAM role that BlueXP can assume or an AWS access key and secret key.
If you choose Assume Role, you can create the first set of credentials from the Connector deployment wizard. Any additional set of credentials must be created from the Credentials page. They will then be available from the wizard in a drop-down list. Learn how to add additional credentials. -
Details: Provide details about the Connector.
Enter a name for the instance.
Add custom tags (metadata) to the instance.
Choose whether you want BlueXP to create a new role that has the required permissions, or if you want to select an existing role that you set up with the required permissions.
Choose whether you want to encrypt the Connector's EBS disks. You have the option to use the default encryption key or to use a custom key.
Network: Specify a VPC, subnet, and key pair for the instance, choose whether to enable a public IP address, and optionally specify a proxy configuration.
Make sure that you have the correct key pair to use with the Connector. Without a key pair, you will not be able to access the Connector virtual machine.
Security Group: Choose whether to create a new security group or whether to select an existing security group that allows the required inbound and outbound rules.
Review: Review your selections to verify that your set up is correct.
Select Add.
The instance should be ready in about 7 minutes. You should stay on the page until the process is complete.
After the process is complete, the Connector is available for use from BlueXP.
If you have Amazon S3 buckets in the same AWS account where you created the Connector, you'll see an Amazon S3 working environment appear on the BlueXP canvas automatically. Learn how to manage S3 buckets from BlueXP
