Prepare for deployment in private mode
Prepare your environment before you deploy BlueXP in private mode. For example, you need to review host requirements, prepare networking, set up permissions, and more.
If you want to use BlueXP in the AWS Secret Cloud or the AWS Top Secret Cloud, then you should follow separate instructions to get started in those environments. Learn how to get started with Cloud Volumes ONTAP in the AWS Secret Cloud or Top Secret Cloud |
Step 1: Understand how private mode works
Before you get started, you should have an understanding of how BlueXP works in private mode.
For example, you should understand that you need to use the browser-based interface that is available locally from the BlueXP Connector that you need to install. You can't access BlueXP from the web-based console that's provided through the SaaS layer.
In addition, not all BlueXP services are available.
Step 2: Review installation options
In private mode, you can install the Connector on premises or in the cloud by manually installing the Connector on your own Linux host.
Where you install the Connector determines which BlueXP services and features are available when using private mode. For example, the Connector must be installed in the cloud if you want to deploy and manage Cloud Volumes ONTAP. Learn more about private mode.
Step 3: Review host requirements
The Connector software must run on a host that meets specific operating system requirements, RAM requirements, port requirements, and so on.
- Dedicated host
The Connector is not supported on a host that is shared with other applications. The host must be a dedicated host.
- Supported operating systems
Ubuntu 22.04 LTS
CentOS 7.6, 7.7, 7.8, and 7.9
Red Hat Enterprise Linux 7.6, 7.7, 7.8, and 7.9
The host must be registered with Red Hat Subscription Management. If it's not registered, the host can't access repositories to update required 3rd-party software during Connector installation.
The Connector is supported on English-language versions of these operating systems.
- Hypervisor
A bare metal or hosted hypervisor that is certified to run Ubuntu, CentOS, or Red Hat Enterprise Linux is required.
- CPU
4 cores or 4 vCPUs
- RAM
14 GB
- AWS EC2 instance type
An instance type that meets the CPU and RAM requirements above. We recommend t3.xlarge.
- Azure VM size
An instance type that meets the CPU and RAM requirements above. We recommend DS3 v2.
- Google Cloud machine type
An instance type that meets the CPU and RAM requirements above. We recommend n2-standard-4.
The Connector is supported in Google Cloud on a VM instance with an OS that supports Shielded VM features
- Disk space in /opt
100 GiB of space must be available
- Disk space in /var
20 GiB of space must be available
- Docker Engine
Docker Engine is required on the host before you install the Connector.
The minimum supported version is 19.3.1.
The maximum supported version is 25.0.5.
Step 4: Prepare networking for the Connector
Set up your networking so the Connector can manage resources and processes within your public cloud environment. Other than having a virtual network and subnet for the Connector, you'll need to ensure that the following requirements are met.
- Connections to target networks
The Connector must have a network connection to the location where you plan to manage storage. For example, the VPC or VNet where you plan to deploy Cloud Volumes ONTAP, or the data center where your on-premises ONTAP clusters reside.
- Endpoints for day-to-day operations
The Connector contacts the following endpoints to manage resources and processes within your public cloud environment.
Endpoints Purpose AWS services (amazonaws.com):
CloudFormation
Elastic Compute Cloud (EC2)
Identity and Access Management (IAM)
Key Management Service (KMS)
Security Token Service (STS)
Simple Storage Service (S3)
To manage resources in AWS. The exact endpoint depends on the AWS region that you're using. Refer to AWS documentation for details
https://management.azure.com
https://login.microsoftonline.com
https://blob.core.windows.net
https://core.windows.netTo manage resources in Azure public regions.
https://management.azure.microsoft.scloud
https://login.microsoftonline.microsoft.scloud
https://blob.core.microsoft.scloud
https://core.microsoft.scloudTo manage resources in the Azure IL6 region.
https://management.chinacloudapi.cn
https://login.chinacloudapi.cn
https://blob.core.chinacloudapi.cn
https://core.chinacloudapi.cnTo manage resources in Azure China regions.
https://www.googleapis.com/compute/v1/
https://compute.googleapis.com/compute/v1
https://cloudresourcemanager.googleapis.com/v1/projects
https://www.googleapis.com/compute/beta
https://storage.googleapis.com/storage/v1
https://www.googleapis.com/storage/v1
https://iam.googleapis.com/v1
https://cloudkms.googleapis.com/v1
https://www.googleapis.com/deploymentmanager/v2/projectsTo manage resources in Google Cloud.
- Public IP address in Azure
If you want to use a public IP address with the Connector VM in Azure, the IP address must use a Basic SKU to ensure that BlueXP uses this public IP address.
If you use a Standard SKU IP address instead, then BlueXP uses the private IP address of the Connector, instead of the public IP. If the machine that you're using to access the BlueXP Console doesn't have access to that private IP address, then actions from the BlueXP Console will fail.
- Proxy server
If your organization requires deployment of a proxy server for all outgoing internet traffic, obtain the following information about your HTTP or HTTPS proxy. You'll need to provide this information during installation.
IP address
Credentials
HTTPS certificate
Note that BlueXP does not support transparent proxy servers.
With private mode, the only time that BlueXP sends outbound traffic is to your cloud provider in order to create a Cloud Volumes ONTAP system. -
- Ports
There's no incoming traffic to the Connector, unless you initiate it.
HTTP (80) and HTTPS (443) provide access to the BlueXP console. SSH (22) is only needed if you need to connect to the host for troubleshooting.
- Enable NTP
If you're planning to use BlueXP classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the BlueXP Connector system and the BlueXP classification system so that the time is synchronized between the systems. Learn more about BlueXP classification
Step 5: Prepare cloud permissions
If the Connector is installed in the cloud and you are planning to create Cloud Volumes ONTAP systems, then BlueXP requires permissions from your cloud provider. You need to set up permissions in your cloud provider and then associate those permission with the Connector instance after you install it.
To view the required steps, select the authentication option that you'd like to use for your cloud provider.
Use an IAM role to provide the Connector with permissions. You'll need to manually attach the role to the EC2 instance for the Connector.
Log in to the AWS console and navigate to the IAM service.
Create a policy:
Select Policies > Create policy.
Select JSON and copy and paste the contents of the IAM policy for the Connector.
Finish the remaining steps to create the policy.
Create an IAM role:
Select Roles > Create role.
Select AWS service > EC2.
Add permissions by attaching the policy that you just created.
Finish the remaining steps to create the role.
You now have an IAM role for the Connector EC2 instance.
Set up permissions and an access key for an IAM user. You'll need to provide BlueXP with the AWS access key after you install the Connector and set up BlueXP.
Create a policy:
Depending on the BlueXP services that you're planning to use, you might need to create a second policy.
For standard regions, the permissions are spread across two policies. Two policies are required due to a maximum character size limit for managed policies in AWS. Learn more about IAM policies for the Connector.
Attach the policies to an IAM user.
Ensure that the user has an access key that you can add to BlueXP after you install the Connector.
The account now has the required permissions.
Create an Azure custom role with the required permissions. You'll assign this role to the Connector VM.
Note that you can create an Azure custom role using the Azure portal, Azure PowerShell, Azure CLI, or REST API. The following steps show how to create the role using the Azure CLI. If you would prefer to use a different method, refer to Azure documentation
Enable a system-assigned managed identity on the VM where you plan to install the Connector so that you can provide the required Azure permissions through a custom role.
Copy the contents of the custom role permissions for the Connector and save them in a JSON file.
Modify the JSON file by adding Azure subscription IDs to the assignable scope.
You should add the ID for each Azure subscription that you want to use with BlueXP.
Example
"AssignableScopes": [ "/subscriptions/d333af45-0d07-4154-943d-c25fbzzzzzzz", "/subscriptions/54b91999-b3e6-4599-908e-416e0zzzzzzz", "/subscriptions/398e471c-3b42-4ae7-9b59-ce5bbzzzzzzz"
Use the JSON file to create a custom role in Azure.
The following steps describe how to create the role by using Bash in Azure Cloud Shell.
Start Azure Cloud Shell and choose the Bash environment.
Upload the JSON file.
Use the Azure CLI to create the custom role:
az role definition create --role-definition Connector_Policy.json
You should now have a custom role called BlueXP Operator that you can assign to the Connector virtual machine.
Create and set up a service principal in Microsoft Entra ID and obtain the Azure credentials that BlueXP needs. You'll need to provide BlueXP with these credentials after you install the Connector and set up BlueXP.
Ensure that you have permissions in Azure to create an Active Directory application and to assign the application to a role.
For details, refer to Microsoft Azure Documentation: Required permissions
From the Azure portal, open the Microsoft Entra ID service.
In the menu, select App registrations.
Select New registration.
Specify details about the application:
Name: Enter a name for the application.
Account type: Select an account type (any will work with BlueXP).
Redirect URI: You can leave this field blank.
Select Register.
You've created the AD application and service principal.
Create a custom role:
You should add the ID for each Azure subscription from which users will create Cloud Volumes ONTAP systems.
Example
Assign the application to the role:
From the Azure portal, open the Subscriptions service.
Select the subscription.
Select Access control (IAM) > Add > Add role assignment.
In the Role tab, select the BlueXP Operator role and select Next.
In the Members tab, complete the following steps:
Keep User, group, or service principal selected.
Select Select members.
Search for the name of the application.
Here's an example:
Select the application and select Select.
Select Next.
Select Review + assign.
The service principal now has the required Azure permissions to deploy the Connector.
If you want to deploy Cloud Volumes ONTAP from multiple Azure subscriptions, then you must bind the service principal to each of those subscriptions. BlueXP enables you to select the subscription that you want to use when deploying Cloud Volumes ONTAP.
In the Microsoft Entra ID service, select App registrations and select the application.
Select API permissions > Add a permission.
Under Microsoft APIs, select Azure Service Management.
Select Access Azure Service Management as organization users and then select Add permissions.
Copy the Application (client) ID and the Directory (tenant) ID.
When you add the Azure account to BlueXP, you need to provide the application (client) ID and the directory (tenant) ID for the application. BlueXP uses the IDs to programmatically sign in.
Open the Microsoft Entra ID service.
Select App registrations and select your application.
Select Certificates & secrets > New client secret.
Provide a description of the secret and a duration.
Select Add.
Copy the value of the client secret.
You now have a client secret that BlueXP can use it to authenticate with Microsoft Entra ID.
Your service principal is now setup and you should have copied the application (client) ID, the directory (tenant) ID, and the value of the client secret. You need to enter this information in BlueXP when you add an Azure account.
Create a role and apply it to a service account that you'll use for the Connector VM instance.
Create a custom role in Google Cloud:
Create a YAML file that includes the permissions defined in the Connector policy for Google Cloud.
From Google Cloud, activate cloud shell.
Upload the YAML file that includes the required permissions for the Connector.
Create a custom role by using the
gcloud iam roles create
command.The following example creates a role named "connector" at the project level:
gcloud iam roles create connector --project=myproject --file=connector.yaml
Create a service account in Google Cloud:
From the IAM & Admin service, select Service Accounts > Create Service Account.
Enter service account details and select Create and Continue.
Select the role that you just created.
You now have a service account that you can assign to the Connector VM instance.
Step 6: Enable Google Cloud APIs
Several APIs are required to deploy Cloud Volumes ONTAP in Google Cloud.
Enable the following Google Cloud APIs in your project
Cloud Deployment Manager V2 API
Cloud Logging API
Cloud Resource Manager API
Compute Engine API
Identity and Access Management (IAM) API
Cloud Key Management Service (KMS) API
(Required only if you are planning to use BlueXP backup and recovery with customer-managed encryption keys (CMEK))
