Known limitations in Azure
Contributors netapp-rlithman netapp-bcammett
The following known limitations are specific to Cloud Volumes ONTAP in Microsoft Azure. Be sure to also review Limitations for Cloud Volumes ONTAP in all cloud providers.
Flash Cache limitations
Some VM types include local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache. Note the following limitations for Flash Cache:
  • Compression must be disabled on all volumes to take advantage of the Flash Cache performance improvements up to Cloud Volumes ONTAP 9.12.0. When you deploy or upgrade to Cloud Volumes ONTAP 9.12.1, you don't need to disable compression.
    You can choose no storage efficiency when creating a volume from BlueXP, or you can create a volume and then disable data compression by using the CLI.
  • Cache rewarming after a reboot is not supported with Cloud Volumes ONTAP.
HA limitations
HA pairs aren't supported in some regions.
