Known limitations in Google Cloud
Contributors netapp-bcammett netapp-driley netapp-rlithman
The following known limitations are specific to Cloud Volumes ONTAP in Google Cloud Platform. Be sure to also review Limitations for Cloud Volumes ONTAP in all cloud providers.
Limitation with packet mirroring
Packet mirroring must be disabled in the Google Cloud VPC in which you deploy Cloud Volumes ONTAP.
Cloud Volumes ONTAP can't operate properly if packet mirroring is enabled.
Google Private Service Connect limitations
If you leverage Google Private Service Connect within the VPC that you are deploying Cloud Volumes ONTAP into, you will need to implement DNS records that forward traffic to the required BlueXP API Endpoints.
Tiering data from Cloud Volumes ONTAP into a Google Cloud Storage bucket is not currently supported with Private Service Connect.
