Storage limits in Azure
Contributors netapp-rlithman netapp-driley netapp-bcammett
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering.
NetApp doesn't support exceeding the system capacity limit. If you reach the licensed capacity limit, BlueXP displays an action required message and no longer allows you to add additional disks.
License Maximum system capacity (disks + object storage)
Freemium
500 GiB
PAYGO Explore
2 TiB (data tiering is not supported with Explore)
PAYGO Standard
10 TiB
PAYGO Premium
368 TiB
Node-based license
2 PiB (requires multiple licenses)
Capacity-based license
2 PiB
For HA, is the license capacity limit per node or for the entire HA pair?
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
Aggregate limits
Cloud Volumes ONTAP uses Azure storage as disks and groups them into aggregates. Aggregates provide storage to volumes.
Parameter Limit
Maximum number of aggregates
Same as the disk limit
Maximum aggregate size 1
384 TiB of raw capacity for single node 2
352 TiB of raw capacity for single node with PAYGO
96 TiB of raw capacity for HA pairs with page blob
384 TiB of raw capacity for HA pairs with managed disks
Disks per aggregate
1-12 3
Maximum number of RAID groups per aggregate
1
Notes:
  1. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  2. If using node-based licensing, two BYOL licenses are required to reach 384 TiB.
  3. All disks in an aggregate must be the same size.
Disk and tiering limits by VM size
Capacity limits are different depending on the VM size that you use and whether you're using a single node system or an HA pair.
The following notes provide details about the numbers that you'll see in the tables below:
  • The disk limits are specific to disks that contain user data.
    The limits do not include the root disk, core disk, and VNVRAM.
  • A maximum system capacity is listed when using disks alone and when using disks and cold data tiering to object storage.
  • Single node and HA systems which use managed disks have a maximum of 32 TiB per disk. The number of supported disks varies by VM size.
  • HA systems which use page blobs have a maximum of 8 TiB per page blob. The number of supported disks varies by VM size.
  • The 896 TiB disk-based limit that's listed for single node systems with certain VM sizes is the tested limit.
Limits for capacity-based licensing
The following disk limits apply to Cloud Volumes ONTAP systems that use a capacity-based licensing package. Learn about Cloud Volumes ONTAP licensing options
Single node
VM size Max data disks per node Max system capacity with disks alone Max system capacity with disks and data tiering
DS4_v2
29
896 TiB
2 PiB
DS5_v2
61
896 TiB
2 PiB
DS13_v2
29
896 TiB
2 PiB
DS14_v2
61
896 TiB
2 PiB
DS15_v2
61
896 TiB
2 PiB
E4s_v3
5
160 TiB
2 PiB
E8s_v3
13
416 TiB
2 PiB
E32s_v3
29
896 TiB
2 PiB
E48s_v3
29
896 TiB
2 PiB
E64is_v3
29
896 TiB
2 PiB
E4ds_v4
5
160 TiB
2 PiB
E8ds_v4
13
416 TiB
2 PiB
E32ds_v4
29
896 TiB
2 PiB
E48ds_v4
29
896 TiB
2 PiB
E80ids_v4
61
896 TiB
2 PiB
E4ds_v5
5
160 TiB
2 PiB
E8ds_v5
13
416 TiB
2 PiB
E20ds_v5
29
896 TiB
2 PiB
E32ds_v5
29
896 TiB
2 PiB
E48ds_v5
29
896 TiB
2 PiB
E64ds_v5
29
896 TiB
2 PiB
L8s_v3
12
384 TiB
2 PiB
L16s_v3
28
896 TiB
2 PiB
L32s_v3
28
896 TiB
2 PiB
L48s_v3
28
896 TiB
2 PiB
L64s_v3
28
896 TiB
2 PiB
HA pairs in a single availability zone with page blobs
VM size Max data disks for an HA pair Max system capacity with disks alone Max system capacity with disks and data tiering
DS4_v2
29
232 TiB
2 PiB
DS5_v2
61
488 TiB
2 PiB
DS13_v2
29
232 TiB
2 PiB
DS14_v2
61
488 TiB
2 PiB
DS15_v2
61
488 TiB
2 PiB
E8s_v3
13
104 TiB
2 PiB
E48s_v3
29
232 TiB
2 PiB
E8ds_v4
13
104 TiB
2 PiB
E32ds_v4
29
232 TiB
2 PiB
E48ds_v4
29
232 TiB
2 PiB
E80ids_v4
61
488 TiB
2 PiB
HA pairs in a single availability zone with shared managed disks
E8ds_v4
12
384 TiB
2 PiB
E32ds_v4
28
896 TiB
2 PiB
E48ds_v4
28
896 TiB
2 PiB
E80ids_v4
28
896 TiB
2 PiB
E8ds_v5
12
384 TiB
2 PiB
E20ds_v5
28
896 TiB
2 PiB
E32ds_v5
28
896 TiB
2 PiB
E48ds_v5
28
896 TiB
2 PiB
E64ds_v5
28
896 TiB
2 PiB
L16s_v3
28
896 TiB
2 PiB
L32s_v3
28
896 TiB
2 PiB
L48s_v3
28
896 TiB
2 PiB
L64s_v3
28
896 TiB
2 PiB
HA pairs in multiple availability zones with shared managed disks
E8ds_v4
12
384 TiB
2 PiB
E32ds_v4
28
896 TiB
2 PiB
E48ds_v4
28
896 TiB
2 PiB
E80ids_v4
28
896 TiB
2 PiB
E8ds_v5
12
384 TiB
2 PiB
E20ds_v5
28
896 TiB
2 PiB
E32ds_v5
28
896 TiB
2 PiB
E48ds_v5
28
896 TiB
2 PiB
E64ds_v5
28
896 TiB
2 PiB
L16s_v3
28
896 TiB
2 PiB
L32s_v3
28
896 TiB
2 PiB
L48s_v3
28
896 TiB
2 PiB
L64s_v3
28
896 TiB
2 PiB
Limits for node-based licensing
The following disk limits apply to Cloud Volumes ONTAP systems that use node-based licensing, which is the previous generation licensing model that enabled you to license Cloud Volumes ONTAP by node. Node-based licensing is still available for existing customers.
You can purchase multiple node-based licenses for a Cloud Volumes ONTAP BYOL single node or HA pair system to allocate more than 368 TiB of capacity, up to the maximum tested and supported system capacity limit of 2 PiB. Be aware that disk limits can prevent you from reaching the capacity limit by using disks alone. You can go beyond the disk limit by tiering inactive data to object storage. Learn how to add additional system licenses to Cloud Volumes ONTAP. Though Cloud Volumes ONTAP supports up to the maximum tested and supported system capacity of 2 PiB, crossing the 2 PiB limit results in an unsupported system configuration.
Single node
Single node has two node-based licensing options: PAYGO Premium and BYOL.
Single node with PAYGO Premium
DS5_v2
61
368 TiB
368 TiB
DS14_v2
61
368 TiB
368 TiB
DS15_v2
61
368 TiB
368 TiB
E32s_v3
29
368 TiB
368 TiB
E48s_v3
29
368 TiB
368 TiB
E64is_v3
29
368 TiB
368 TiB
E32ds_v4
29
368 TiB
368 TiB
E48ds_v4
29
368 TiB
368 TiB
E80ids_v4
61
368 TiB
368 TiB
E20ds_v5
29
896 TiB
2 PiB
E32ds_v5
29
896 TiB
2 PiB
E48ds_v5
29
896 TiB
2 PiB
E64ds_v5
29
896 TiB
2 PiB
Single node with BYOL
VM size Max data disks per node Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks + data tiering
Disks alone
DS4_v2
29
368 TiB
368 TiB
896 TiB
2 PiB
DS5_v2
61
368 TiB
368 TiB
896 TiB
2 PiB
DS13_v2
29
368 TiB
368 TiB
896 TiB
2 PiB
DS14_v2
61
368 TiB
368 TiB
896 TiB
2 PiB
DS15_v2
61
368 TiB
368 TiB
896 TiB
2 PiB
L8s_v2
13
368 TiB
368 TiB
416 TiB
2 PiB
E4s_v3
5
160 TiB
368 TiB
160 TiB
2 PiB
E8s_v3
13
368 TiB
368 TiB
416 TiB
2 PiB
E32s_v3
29
368 TiB
368 TiB
896 TiB
2 PiB
E48s_v3
29
368 TiB
368 TiB
896 TiB
2 PiB
E64is_v3
29
368 TiB
368 TiB
896 TiB
2 PiB
E4ds_v4
5
160 TiB
368 TiB
160 TiB
2 PiB
E8ds_v4
13
368 TiB
368 TiB
416 TiB
2 PiB
E32ds_v4
29
368 TiB
368 TiB
896 TiB
2 PiB
E48ds_v4
29
368 TiB
368 TiB
896 TiB
2 PiB
E80ids_v4
61
368 TiB
368 TiB
896 TiB
2 PiB
E4ds_v5
5
160 TiB
368 TiB
160 TiB
2 PiB
E8ds_v5
13
368 TiB
368 TiB
416 TiB
2 PiB
E20ds_v5
29
368 TiB
368 TiB
896 TiB
2 PiB
E32ds_v5
29
368 TiB
368 TiB
896 TiB
2 PiB
E48ds_v5
29
368 TiB
368 TiB
896 TiB
2 PiB
E64ds_v5
29
368 TiB
368 TiB
896 TiB
2 PiB
HA pairs
HA pairs have two configuration types: page blob and multiple availability zone. Each configuration has two node-based licensing options: PAYGO Premium and BYOL.
PAYGO Premium: HA pairs in single availability zone with page blobs
DS5_v2
61
368 TiB
368 TiB
DS14_v2
61
368 TiB
368 TiB
DS15_v2
61
368 TiB
368 TiB
E8s_v3
13
104 TiB
368 TiB
E48s_v3
29
232 TiB
368 TiB
E32ds_v4
29
232 TiB
368 TiB
E48ds_v4
29
232 TiB
368 TiB
E80ids_v4
61
368 TiB
368 TiB
PAYGO Premium: HA pairs in a multiple availability zone configuration with shared managed disks
E32ds_v4
28
368 TiB
368 TiB
E48ds_v4
28
368 TiB
368 TiB
E80ids_v4
28
368 TiB
368 TiB
E20ds_v5
28
896 TiB
2 PiB
E32ds_v5
28
896 TiB
2 PiB
E48ds_v5
28
896 TiB
2 PiB
E64ds_v5
28
896 TiB
2 PiB
BYOL: HA pairs in single availability zone with page blobs
VM size Max data disks for an HA pair Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks alone
DS4_v2
29
232 TiB
368 TiB
232 TiB
2 PiB
DS5_v2
61
368 TiB
368 TiB
488 TiB
2 PiB
DS13_v2
29
232 TiB
368 TiB
232 TiB
2 PiB
DS14_v2
61
368 TiB
368 TiB
488 TiB
2 PiB
DS15_v2
61
368 TiB
368 TiB
488 TiB
2 PiB
E8s_v3
13
104 TiB
368 TiB
104 TiB
2 PiB
E48s_v3
29
232 TiB
368 TiB
232 TiB
2 PiB
E8ds_v4
13
104 TiB
368 TiB
104 TiB
2 PiB
E32ds_v4
29
232 TiB
368 TiB
232 TiB
2 PiB
E48ds_v4
29
232 TiB
368 TiB
232 TiB
2 PiB
E80ids_v4
61
368 TiB
368 TiB
488 TiB
2 PiB
BYOL: HA pairs in a multiple availability zone configuration with shared managed disks
Disks alone
Disks alone
E8ds_v4
12
368 TiB
368 TiB
368 TiB
2 PiB
E32ds_v4
28
368 TiB
368 TiB
368 TiB
2 PiB
E48ds_v4
28
368 TiB
368 TiB
368 TiB
2 PiB
E80ids_v4
28
368 TiB
368 TiB
368 TiB
2 PiB
E8ds_v5
12
368 TiB
368 TiB
368 TiB
2 PiB
E20ds_v5
28
368 TiB
368 TiB
368 TiB
2 PiB
E32ds_v5
28
368 TiB
368 TiB
368 TiB
2 PiB
E48ds_v5
28
368 TiB
368 TiB
368 TiB
2 PiB
E64ds_v5
28
368 TiB
368 TiB
368 TiB
2 PiB
Storage VM limits
Some configurations enable you to create additional storage VMs (SVMs) for Cloud Volumes ONTAP.
These are the tested limits. While it is theoretically possible to configure additional storage VMs, it's not supported.
License type Storage VM limit
Freemium
24 storage VMs total 1,2
Capacity-based PAYGO or BYOL 3
Node-based BYOL 4
Node-based PAYGO
  • 1 storage VM for serving data
  • 1 storage VM for disaster recovery
  1. These 24 storage VMs can serve data or be configured for disaster recovery (DR).
  2. Each storage VM can have up to three LIFs where two are data LIFs and one is an SVM management LIF.
  3. For capacity-based licensing, there are no extra licensing costs for additional storage VMs, but there is a 4 TiB minimum capacity charge per storage VM. For example, if you create two storage VMs and each has 2 TiB of provisioned capacity, you'll be charged a total of 8 TiB.
  4. For node-based BYOL, an add-on license is required for each additional data-serving storage VM beyond the first storage VM that comes with Cloud Volumes ONTAP by default. Contact your account team to obtain a storage VM add-on license.
    Storage VMs that you configure for disaster recovery (DR) don't require an add-on license (they are free of charge), but they do count against the storage VM limit. For example, if you have 12 data-serving storage VMs and 12 storage VMs configured for disaster recovery, then you've reached the limit and can't create any additional storage VMs.
File and volume limits
Logical storage Parameter Limit
Files
Maximum size 2
128 TB
Maximum per volume
Volume size dependent, up to 2 billion
FlexClone volumes
Hierarchical clone depth 1
499
FlexVol volumes
Maximum per node
500
Minimum size
20 MB
Maximum size 3
300 TiB
Qtrees
Maximum per FlexVol volume
4,995
Snapshot copies
1,023
  1. Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
  2. Beginning with ONTAP 9.12.1P2, the limit is 128 TB. In ONTAP 9.11.1 and earlier versions, the limit is 16 TB.
  3. FlexVol volume creation up to maximum size of 300 TiB is supported using the following tools and minimum versions:
    • System Manager and the ONTAP CLI starting from Cloud Volumes ONTAP 9.12.1 P2 and 9.13.0 P2
    • BlueXP starting from Cloud Volumes ONTAP 9.13.1
iSCSI storage limits
iSCSI storage Parameter Limit
LUNs
Maximum per node
1,024
Maximum number of LUN maps
1,024
Maximum size
16 TiB
Maximum per volume
512
igroups
Maximum per node
256
Initiators
Maximum per node
512
Maximum per igroup
128
iSCSI sessions
Maximum per node
1,024
LIFs
Maximum per port
32
Maximum per portset
32
Portsets
Maximum per node
256
