Storage limits
Contributors netapp-bcammett
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering. NetApp doesn't support exceeding this limit.
For some configurations, disk limits prevent you from reaching the 368 TiB capacity limit by using disks alone. In those cases, you can reach the 368 TiB capacity limit by tiering inactive data to object storage. Refer to capacity and disk limits below for more details.
License Maximum system capacity (disks + object storage)
Explore
2 TiB (data tiering is not supported with Explore)
Standard
10 TiB
Premium
368 TiB
BYOL
368 TiB per license
For HA, is the license capacity limit per node or for the entire HA pair?
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
For an HA system in AWS, does mirrored data count against the capacity limit?
No, it doesn't. Data in an AWS HA pair is synchronously mirrored between the nodes so that the data is available in the event of failure. For example, if you purchase an 8 TiB disk on node A, Cloud Manager also allocates an 8 TiB disk on node B that is used for mirrored data. While 16 TiB of capacity was provisioned, only 8 TiB counts against the license limit.
Capacity and disk limits by AWS EC2 instance
Cloud Volumes ONTAP uses EBS volumes as disks. The disk limits below are specific to disks that contain user data. The limits do not include the boot disk and root disk.
The maximum EBS disk size is 16 TiB. The number of supported disks varies by instance type.
The tables below shows the maximum capacity by instance type with just EBS disks, and with disks and tiering to object storage.
Single node with a Premium license
Instance type Max disks per node Max system capacity with disks alone Max system capacity with disks and data tiering
c4.4xlarge
34
368 TiB
368 TiB
c4.8xlarge
34
368 TiB
368 TiB
c5d.4xlarge
23
368 TiB
368 TiB
c5d.9xlarge
23
368 TiB
368 TiB
m4.4xlarge
34
368 TiB
368 TiB
m5.4xlarge
23
368 TiB
368 TiB
r4.2xlarge
34
368 TiB
368 TiB
r5.2xlarge
23
368 TiB
368 TiB
r5d.2xlarge
23
368 TiB
368 TiB
Single node with one or more BYOL licenses
Instance type Max disks per node Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks + data tiering
Disks alone
c4.4xlarge
34
368 TiB
368 TiB
544 TiB
368 TiB x each license
c4.8xlarge
34
368 TiB
368 TiB
544 TiB
c5d.4xlarge
23
368 TiB
368 TiB
368 TiB
c5d.9xlarge
23
368 TiB
368 TiB
368 TiB
m4.xlarge
34
368 TiB
368 TiB
544 TiB
m4.2xlarge
34
368 TiB
368 TiB
544 TiB
m4.4xlarge
34
368 TiB
368 TiB
544 TiB
m5.xlarge
23
368 TiB
368 TiB
368 TiB
m5.2xlarge
23
368 TiB
368 TiB
368 TiB
m5.4xlarge
23
368 TiB
368 TiB
368 TiB
r4.xlarge
34
368 TiB
368 TiB
544 TiB
r4.2xlarge
34
368 TiB
368 TiB
544 TiB
r5.xlarge
23
368 TiB
368 TiB
368 TiB
r5.2xlarge
23
368 TiB
368 TiB
368 TiB
r5d.2xlarge
23
368 TiB
368 TiB
368 TiB
HA pairs with a Premium license
c4.4xlarge
31
368 TiB
368 TiB
c4.8xlarge
31
368 TiB
368 TiB
c5d.4xlarge
20
320 TiB
368 TiB
c5d.9xlarge
20
320 TiB
368 TiB
m4.4xlarge
31
368 TiB
368 TiB
m5.4xlarge
20
320 TiB
368 TiB
r4.2xlarge
31
368 TiB
368 TiB
r5.2xlarge
20
320 TiB
368 TiB
r5d.2xlarge
20
320 TiB
368 TiB
HA pairs with one or more BYOL licenses
Disks alone
Disks alone
c4.4xlarge
31
368 TiB
368 TiB
496 TiB
c4.8xlarge
31
368 TiB
368 TiB
496 TiB
c5d.4xlarge
20
320 TiB
368 TiB
320 TiB
c5d.9xlarge
20
320 TiB
368 TiB
320 TiB
m4.xlarge
31
368 TiB
368 TiB
496 TiB
m4.2xlarge
31
368 TiB
368 TiB
496 TiB
m4.4xlarge
31
368 TiB
368 TiB
496 TiB
m5.xlarge
20
320 TiB
368 TiB
320 TiB
m5.2xlarge
20
320 TiB
368 TiB
320 TiB
m5.4xlarge
20
320 TiB
368 TiB
320 TiB
r4.xlarge
31
368 TiB
368 TiB
496 TiB
r4.2xlarge
31
368 TiB
368 TiB
496 TiB
r5.xlarge
20
320 TiB
368 TiB
320 TiB
r5.2xlarge
20
320 TiB
368 TiB
320 TiB
r5d.2xlarge
20
320 TiB
368 TiB
320 TiB
Disk and tiering limits by Azure VM size
The disk limits below are specific to disks that contain user data. The limits do not include the boot disk and root disk. The tables below show the maximum system capacity by VM size with managed disks alone, and with disks and cold data tiering to object storage.
Disk limits are shown by VM size for Premium and BYOL licenses only because disk limits can’t be reached with Explore or Standard licenses due to system capacity limits.
  • Single node systems can use Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks, with up to 32 TiB per disk. The number of supported disks varies by VM size.
  • HA systems use Premium page blobs as disks, with up to 8 TiB per page blob. The number of supported disks varies by VM size.
VM size Max disks per node Max system capacity with disks alone Max system capacity with disks and data tiering
DS3_v2
15
368 TiB
Tiering not supported
DS4_v2
31
368 TiB
368 TiB
DS5_v2
63
368 TiB
368 TiB
DS13_v2
31
368 TiB
368 TiB
DS14_v2
63
368 TiB
368 TiB
Note For some VM types, you'll need several BYOL licenses to reach the max system capacity listed below. For example, you'd need 6 BYOL licenses to reach 2 PiB with DS5_v2.
VM size Max disks per node Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks alone
DS3_v2
15
368 TiB
480 TiB
DS4_v2
31
368 TiB
368 TiB
896 TiB
DS5_v2
63
368 TiB
368 TiB
896 TiB
DS13_v2
31
368 TiB
368 TiB
896 TiB
DS14_v2
63
368 TiB
368 TiB
896 TiB
VM size Max data disks for an HA pair Max system capacity with disks alone Max system capacity with disks and data tiering
DS4_v2
31
368 TiB
DS5_v2
63
368 TiB
DS13_v2
31
368 TiB
DS14_v2
63
368 TiB
DS15_v2
63
368 TiB
Note For some VM types, you'll need several BYOL licenses to reach the max system capacity listed below. For example, you'd need 3 BYOL licenses to reach 1 PiB with DS5_v2.
VM size Max data disks for an HA pair Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks alone
DS4_v2
31
368 TiB
248 TiB
DS5_v2
63
368 TiB
504 TiB
DS13_v2
31
368 TiB
248 TiB
DS14_v2
63
368 TiB
504 TiB
DS15_v2
63
368 TiB
504 TiB
Aggregate limits in AWS
Cloud Volumes ONTAP uses AWS volumes as disks and groups them into aggregates. Aggregates provide storage to volumes.
Parameter Limit
Maximum number of aggregates
Single node: Same as the disk limit
HA pairs: 18 in a node 1
Maximum aggregate size
96 TiB of raw capacity 2
Disks per aggregate
1-6 3
Maximum number of RAID groups per aggregate
1
Notes:
  1. It is not possible to create 18 aggregates on both nodes in an HA pair because doing so would exceed the data disk limit.
  2. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  3. All disks in an aggregate must be the same size.
Aggregate limits in Azure
Cloud Volumes ONTAP uses Azure storage as disks and groups them into aggregates. Aggregates provide storage to volumes.
Parameter Limit
200 TiB of raw capacity for single node 1
96 TiB of raw capacity for HA pairs 1
Disks per aggregate
1-12 2
Single node: 1
HA pairs: 6
Notes:
  1. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  2. All disks in an aggregate must be the same size.
Logical storage limits
Logical storage Parameter Limit
Storage virtual machines (SVMs)
Maximum number for Cloud Volumes ONTAP
(HA pair or single node)
One data-serving SVM and one destination SVM used for disaster recovery. You can activate the destination SVM for data access if there’s an outage on the source SVM. 1
The one data-serving SVM spans the entire Cloud Volumes ONTAP system (HA pair or single node).
Files
Maximum size
16 TiB
Maximum per volume
Volume size dependent, up to 2 billion
FlexClone volumes
Hierarchical clone depth 2
499
FlexVol volumes
Maximum per node
500
Minimum size
20 MB
Maximum size
AWS: Dependent on the size of the aggregate 3
Azure HA: Dependent on the size of the aggregate 3
Azure single node: 100 TiB
Qtrees
Maximum per FlexVol volume
4,995
Snapshot copies
1,023
Notes:
  1. Cloud Manager does not provide any setup or orchestration support for SVM disaster recovery. It also does not support storage-related tasks on an additional SVM. You must use System Manager or the CLI for SVM disaster recovery.
  2. Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
  3. Less than 100 TiB is supported because aggregates for this configuration are limited to 96 TiB of raw capacity.
iSCSI storage limits
iSCSI storage Parameter Limit
LUNs
Maximum per node
1,024
Maximum number of LUN maps
1,024
Maximum size
16 TiB
Maximum per volume
512
igroups
Maximum per node
256
Initiators
Maximum per node
512
Maximum per igroup
128
iSCSI sessions
Maximum per node
1,024
LIFs
Maximum per port
32
Maximum per portset
32
Portsets
Maximum per node
256
