Cloud Insights
Transforming Metrics
Contributors netapp-alavoie dgracenetapp
Cloud Insights provides different transform options for certain metrics in widgets (specifically, those metrics called "Custom" or Integration Metrics, such as from Kubernetes, ONTAP Advanced Data, Telegraf plugins, etc.), allowing you to display the data in a number of ways. When adding transformable metrics to a widget, you are presented with a drop-down giving the following transform choices:
None
Data is displayed as is, with no manipulation.
Rate
Current value divided by the time range since the previous observation.
Cumulative
The accumulation of the sum of previous values and the current value.
Delta
The difference between the previous observation value and the current value.
Delta rate
Delta value divided by the time range since the previous observation.
Cumulative Rate
Cumulative value divided by the time range since the previous observation.
Note that transforming metrics does not change the underlying data itself, but only the way that data is displayed.
