Configuring the Azure NetApp Files data collector
Cloud Insights uses the Azure NetApp Files data collector to acquire inventory and performance data.
Requirements
You need the following information to configure this data collector.
Port requirement: 443 HTTPS
Azure Management Rest IP (management.azure.com)
Azure service principal client ID (user account)
Azure service principal authentication key (user password)
You need to set up an Azure account for Cloud Insights discovery.
Once the account is properly configured and you register the application in Azure, you will have the credentials required to discover the Azure instance with Cloud Insights. The following link describes how to set up the account for discovery:
Configuration
Enter data into the data collector fields according to the table below:
Field | Description |
Azure Service Principal Client ID |
Sign-in ID to Azure |
Azure Tenant ID |
Azure Tenant ID |
Azure Service Principal Authentication Key |
Login authentication key |
I understand Microsoft bills me for API requests |
Check this to verify your understanding that Microsoft bills you for API requests made by Insight polling. |
Advanced Configuration
Inventory Poll Interval (min) |
The default is 60 |
Troubleshooting
The credentials used by your ANF data collector must not have access to any Azure subscriptions that contain ANF volumes.
If Reader access causes performance collection to fail, try granting contributor access on a resource group level.
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
