Oracle ZFS Storage Appliance data collector
Cloud Insights uses the Oracle ZFS Storage Appliance data collector to gather inventory and performance data.
Terminology
Cloud Insights acquires inventory information with the Oracle ZFS data collector. For each asset type acquired by Cloud Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term | Cloud Insights Term |
Disk (SSD) |
Disk |
Cluster |
Storage |
Controller |
Storage Node |
LUN |
Volume |
LUN Map |
Volume Map |
Initiator,Target |
Volume Mask |
Share |
Internal Volume |
Note: These are common terminology mappings only and might not represent every case for this data source.
Requirements
Host names for the ZFS Controller-1 and the ZFS Controller-2
Administrator user name and password
Port requirement: 215 HTTP/HTTPS
Required Performance metrics
Oracle ZFS appliances give storage administators large amounts of flexibility to capture performance statistics. Cloud Insights expects you to have each controller in a high availability pair configured to capture the following metrics:
smb2.ops[share]
nfs3.ops[share]
nfs4.ops[share]
nfs4-1.ops[share]
Failure to have the controller capture any or all of these will likely result in Cloud Insights not having, or underreporting, the workload on the "Internal Volumes".
Configuration
Field | Description |
ZFS Controller-1 Hostname |
Host name for storage controller 1 |
ZFS Controller-2 Hostname |
Host name for storage controller 2 |
User name |
User name for the storage system administrator user account |
Password |
Password for the administrator user account |
Advanced configuration
Connection Type |
HTTPS or HTTP, also displays the default port |
Override Connection Port |
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use |
Inventory poll interval |
The default is 60 seconds |
Performance Poll Interval (sec) |
The default is 300. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: | Try this: |
"Invalid login credentials" |
validate Zfs user account and password |
"Configuration error" with error message “REST Service is disabled” |
Verify REST service is enabled on this device. |
"Configuration error " with error message “User unauthorized for command” |
Likely due to certain roles (for example, 'advanced_analytics') are not included for the configured user <userName>. |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
