SANtricity commands
Add certificate from array
The Add certificate from array command allows you to take a certificate from the array and add it to the CLI package's trust store. The certificate added will only be used by the CLI package.
Supported Arrays
This command applies to the EF600 and EF300 storage arrays.
Syntax
ipAddress1 ipAddress2  trust localCertificate
Parameter Description
IPaddress
Allows you to specify the IP address for the storage array.
Minimum firmware level
8.60
