SANtricity commands
Create storage array directory server
The create storageArray directoryServer command allows you to add a new directory server to be used for authenticating and authorizing users.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Security Admin role.
Syntax
       [domainId="domainId"
       domainNames=("domainName1"..."domainNameN")
       serverUrl="serverUrl"
       [bindAccount="username" bindPassword="password"]
       searchBaseDN="distinguishedName"
       usernameAttribute="attributeName"
       groupAttributes=("attrName1"..."attrNameN")
        [skipConfigurationTest={true | false}]
Parameter Description
domainId
Allows you to specify a unique ID for this domain. If not specified, a unique GUID will be generated.
domainNames
Allows you to specify one or more valid domain names for the directory server. If you enter more than one name, separate the values with a space.
serverUrl
Allows you to specify the URL to access the LDAP server in the form of ldap[s]://hostAddress:port. If the LDAPS protocol is used, ensure that the root/intermediate certificate(s) to validate the directory server's signed certificate is imported using the certificate commands.
bindAccount
Allows you to specify the username or bind ID to be used as the binding account.
bindPassword
Allows you to specify the password to be used as the binding password.
searchBaseDN
Allows you to specify the search base Distinguished Name to search for LDAP user objects for determining group membership.
usernameAttribute
Allows you to specify the attribute to be used to search for user objects for determining group membership. If specified, the string must contain the variable {uid} that will be replaced with the username used during login. Example: sAMAccountName={uid}
groupAttributes
Allows you to set one or more group attributes to be used to look for group Distinguished Names. Distinguished names are used to determine group membership for role mapping.
Note
If you enter more than one group, separate the values with a space.
Note
Using this parameter will clear out existing groups.
Allows you to skip the configuration test before the configuration is saved. The default is false.
SMcli -n Array1 -c "create storageArray directoryServer
domainNames=("company.com") serverUrl="ldap://hqldap.company.com:389"
bindAccount="dummyBindDN" bindPassword="dummyPassword"
searchBaseDN="OU=_Users,DC=hq, DC=company,DC=com"
usernameAttributes="sAMAccountName={uid}" groupAttributes="memberOf";"
SMcli completed successfully.
