Enable controller data transfer
The enable controller dataTransfer
command revives a controller that has become quiesced while running diagnostics.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Syntax
enable controller [(a|b)] dataTransfer
Parameter
Parameter | Description |
The controller that you want to revive. Valid controller identifiers are |
Minimum firmware level
6.10
