Remove array label
Creating your file...
Your file is ready
The Remove array label
command allows you to remove a user-defined label for a storage array.
Supported Arrays
This command applies to the EF600 and EF300 storage arrays.
Syntax
delete storageArrayLabel label userDefinedString delete storageArrayLabel all
Parameter | Description |
Allows you to specify a user-defined label for the storage array. |
Minimum firmware level
8.60
