SANtricity commands
Remove volume LUN mapping
The remove lunMapping command removes the logical unit number (LUN) or namespace ID (NSID) mapping from one or more volumes.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Syntax
remove (volume ["volumeName"] | accessVolume) lunMapping
(host="hostName" | hostGroup=("hostGroupName" | defaultGroup)
Syntax for removing LUN or NSID mapping from more than one volume LUN or NSID mapping
remove (allVolumes | volumes [volumeName1 ... volumeNameN])
lunMapping
Parameter Description
volume
The name of a volume from which you are removing the LUN or NSID mapping. Enclose the volume name double quotation marks (" ") inside square brackets ([ ]).
accessVolume
This parameter removes the access volume.
allVolumes
This parameter removes the LUN mapping from all of the volumes.
volumes
The names of several volumes from which you are removing the LUN or NSID mapping. Enter the names of the volumes using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Separate each of the names with a space.
If the volume names have special characters or consist only of numbers, enter the names using these rules:
  • Enclose each of the names in double quotation marks (" ").
host
The name of the host to which the volume is mapped. Enclose the host name in double quotation marks (" ").
This parameter works only when you are removing LUN or NSID mapping from one volume.
hostGroup
The name of the host group that contains the host to which the volume is mapped. Enclose the host group name in double quotation marks (" "). The defaultGroup value is the host group that contains the host to which the volume is mapped.
Notes
The access volume is the volume in a SAN environment that is used for communication between the storage management software and the storage array controller. The access volume uses a LUN or NSID address and consumes 20 MB of storage space that is not available for application data storage. An access volume is required only for in-band managed storage arrays.
Note
Removing an access volume can damage your configuration — The agent uses the access volumes to communicate with a storage array. If you remove an access volume mapping for a storage array from a host that has an agent running on it, the storage management software is no longer able to manage the storage array through the agent.
You must use the host parameter and the hostGroup parameter when you specify a non-access volume or an access volume. The Script Engine ignores the host parameter or the hostGroup parameter when you use the allVolumes parameter or the volumes parameter.
Minimum firmware level
6.10
