SANtricity commands
Rename SSD cache
Contributors netapp-driley netapp-jsnyder
The set ssdCache command changes the name of the SSD cache.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600, and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Support Admin role.
Syntax
set ssdCache [old_ssdCacheName] userLabel="new_ssdCacheName"
Parameter
Parameter Description
ssdCache
The name of the SSD cache that you want to rename. Enclose the SSD cache name in square brackets ([ ]). If the SSD cache name has special characters or consists only of numbers, you also must enclose the SSD cache name in double quotation marks (" ") inside square brackets.
userLabel
The new name for the SSD cache. Enclose the name in double quotation marks (" ").You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the identifier. Identifiers can have a maximum of 30 characters.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
