SANtricity commands
Reset storage array SOC baseline
The reset storageArray SOCBaseline command resets the baseline for all switch-on-a-chip (SOC) devices that are accessed through the controllers.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
This command resets the baseline by setting all of the SOC counts to 0. This command is valid only for Fibre Channel devices in an arbitrated loop topology.
Syntax
None.
Minimum firmware level
6.16
