SANtricity commands
Save storage array iSCSI statistics
Contributors netapp-driley
The save storageArray iscsiStatistics command saves the iSCSI performance statistics of the storage array to a file.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Note
This command is deprecated and is replaced by the Save storage array host port statistics command.
Syntax
save storageArray iscsiStatistics [(raw | baseline)] file="filename"
Parameter Description
raw
The statistics collected are all statistics from the controller start-of-day. Enclose the parameter in square brackets ([ ]).
baseline
The statistics that are collected are all statistics from the time the controllers were reset to zero using the reset storageArray ibStatsBaseline command. Enclose the parameter in square brackets ([ ]).
file
The file path and the file name to which you want to save the performance statistics. Enclose the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\iscsistat.csv"
The default name of the file that contains the iSCSI performance statistics is iscsi-statistics.csv. You can use any file name, but you must use the .csv extension.
Notes
If you have not reset the iSCSI baseline statistics since the controller start-of-day, the time at the start-of-day is the default baseline time.
Minimum firmware level
7.10
8.41 This command is deprecated.
