SANtricity commands
Set iSER target
Contributors netapp-driley
The set iserTarget command defines properties for an iSER target.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Note
This command is deprecated and is replaced by the Set target properties command.
Syntax
set iserTarget ["userLabel"]
authenticationMethod=(none | chap) |
chapSecret=securityKey |
targetAlias="userLabel"
Parameter Description
iserTarget
The iSER target for which you want to set properties. Enclose the userLabel in double quotation marks (" "). You must also enclose the userLabel in square brackets ([ ]) if the user label is a target alias or angle brackets (< >) if the user label is an iSCSI Qualified Name (IQN).
The means of authenticating your iSCSI session.
chapSecret
The security key that you want to use to authenticate a peer connection.
targetAlias
The new name that you want to use for the target. Enclose the name in double quotation marks (" ").
Notes
Challenge Handshake Authentication Protocol (CHAP) is a protocol that authenticates the peer of a connection. CHAP is based upon the peers sharing a secret. A secret is a security key that is similar to a password.
Use the chapSecret parameter to set up the security keys for initiators that require a mutual authentication. The CHAP secret must be between 12 characters and 57 characters. This table lists the valid characters.
Space
0
1
2
3
4
5
6
7
8
9
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
_
a
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
v
w
x
y
z
Minimum firmware level
8.20
8.41 This command is deprecated.
