SANtricity commands
Update storage array syslog configuration
Contributors netapp-driley
The set storageArray syslog command allows you to change the syslog server address, protocol, or port number.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Security Admin role.
Syntax
set storageArray syslog id="<id>"
serverAddress="<address>"
port=<port> protocol=("udp" | "tcp" | "tls")
components=(componentName=("auditLog") ...)
Parameter Description
serverAddress
Syslog receiver hostname or IP address.
port
Syslog receiver port number.
protocol
Syslog transmission protocol. Acceptable values include UDP, TCP, or TLS.
components
List of component entries that will be logged to the syslog server. Currently, only audit logs are supported.
componentName
Component name; currently only "auditLog" is supported.
Example
SMcli -n Array1 -c "set storageArray syslog
id=\"331998fe-3154-4489-b773-b0bb60c6b48e\"
serverAddress=\"192.168.2.1\" port=514 protocol=\"udp\"
components=(componentName=\"auditLog\");"
ID: 331998fe-3154-4489-b773-b0bb60c6b48e Server Address: 192.168.2.1
Port: 514 Protocol: udp
Components
1. Component Name: auditLog
SMcli completed successfully.
Minimum firmware level
8.42
