SANtricity commands
Show storage array host topology
The show storageArray hostTopology command returns the storage partition topology, the host type labels, and the host type index for the host storage array.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
None.
Notes
This command returns the host topology information similar to this example.
TOPOLOGY DEFINITIONS
 DEFAULT GROUP
  Default type: Windows 2000/Server 2003 Non-Clustered
  Host Group: scott
   Host: scott1
    Host Port: 28:37:48:55:55:55:55:55
     Alias: scott11
     Type: Windows 2000/Server 2003 Clustered
   Host: scott2
    Host Port: 98:77:66:55:44:33:21:23
     Alias: scott21
   Host: Bill
    Host Port: 12:34:55:67:89:88:88:88
     Alias: Bill1
     Type: Windows 2000/Server 2003 Non-Clustered
NVSRAM HOST TYPE INDEX DEFINITIONS
HOST TYPE                         ALUA/AVT STATUS   ASSOCIATED INDEXS
AIX MPIO                          Disabled          9
AVT_4M                            Enabled           5
Factory Default                   Disabled          0
HP-UX                             Enabled           15
Linux (ATTO)                      Enabled           24
Linux (DM-MP)                     Disabled          6
Linux (Pathmanager)               Enabled           25
Mac OS                            Enabled           22
ONTAP                             Disabled          4
SVC                               Enabled           18
Solaris (v11 or Later)            Enabled           17
Solaris (version 10 or earlier)   Disabled          2
VMWare                            Enabled           10 (Default)
Windows                           Enabled           1
Minimum firmware level
5.20
