Start SSD cache locate
The start ssdCache locate
command identifies the Solid State Disks (SSDs) that are logically grouped together to form the SSD cache by blinking the indicator lights on the SSDs.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600, and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Support Admin role.
Context
Use the stop ssdCache locate
command to turn off the indicator lights on the drives.
Syntax
start ssdCache [ssdCacheName] locate
Parameter | Description |
The name of the SSD cache that you want to locate. Enclose the SSD cache name in square brackets ([ ]). If the SSD cache name contains special characters or consists only of numbers, you must enclose the SSD cache name in double quotation marks (" ") inside square brackets. |
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
