SANtricity commands
Stop tray locate
The stop tray locate command turns off the indicator light on the tray that was turned on by the start tray locate command.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Syntax
stop tray locate
None.
Minimum firmware level
6.10
