SANtricity software
Edit access token settings in SANtricity System Manager
Contributors netapp-jolieg netapp-driley
You can edit settings for access tokens, which includes the expiration times and the ability to create new tokens.
Steps
  1. From the left panel, select Settings  Access Management.
  2. Select the Access Tokens tab.
  3. Select View/Edit Access Token Settings.
  4. In the dialog box, you can perform one or both of these tasks:
    • Enable or disable token creation.
    • Change the expiration of existing tokens.
      Note When you de-select the Enable access tokens setting, it prevents both token creation and token authentication. If you later re-enable this setting, unexpired tokens can be re-used. If you want to permanently revoke all existing tokens, see Revoke access tokens.
  5. Click Save.
