How do application-specific workloads help me manage my storage array?
PDF of this doc site
- System Manager
Creating your file...
Your file is ready
The volume characteristics of your application-specific workload dictate how the workload interacts with the components of your storage array and helps determine the performance of your environment under a given configuration.
An application is software such as SQL Server or Exchange. You define one or more workloads to support each application.
