Remove remote storage object
PDF of this doc site
- System Manager
Creating your file...
Your file is ready
After an import completes, you can remove a remote storage object if you no longer want data copied between the local and remote devices.
Before you begin
Make sure that no imports are associated with the remote storage object you plan to remove.
About this task
When you remove a remote storage object, connections between the local and remote devices are removed.
Steps
Select Storage › Remote storage.
From the list, select the remote storage object that you want to remove.
Click Remove.
The Confirm Remove Remote Storage Connection dialog box is displayed.
Confirm the operation by typing
remove
and then clicking Remove.The selected remote storage object is removed.
