SANtricity software
Turn on locator lights in a pool, volume group, or SSD Cache in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
You can locate drives to physically identify all of the drives that comprise a selected pool, volume group, or SSD Cache. An LED indicator lights up on each drive in the selected pool, volume group, or SSD Cache.
Steps
  1. From the left panel, select Storage  Pools and volume groups.
  2. Select the pool, volume group, or SSD Cache you want to locate, and then click the ellipsis icon  Turn on locator lights.
    A dialog box appears that indicates the lights on the drives comprising the selected pool, volume group, or SSD Cache are turned on.
  3. After you successfully locate the drives, click Turn Off.
