E-Series Systems
Browse solution technical reports
Contributors netapp-jsnyder
Splunk
TR-4623: E5700 with Splunk Enterprise
TR-4903: EF300 with Splunk Enterprise
TR-4930: EF600 with Splunk Enterprise
Describes the integrated architecture of the E5700 system and Splunk design. This document also summarizes the performance test results obtained from a Splunk machine log event simulation tool.
Describes the integrated architecture of the EF300 all-flash array and Splunk design. This document also summarizes the performance test results obtained from a Splunk machine log event simulation tool.
Describes the integrated architecture of the EF600 all-flash array and Splunk design. This document also summarizes the performance test results obtained from a Splunk machine log event simulation tool.
Enterprise Databases
TR-4764: Best Practice Guide for Microsoft SQL Server with NetApp EF-Series
TR-4794: Oracle Databases on NetApp EF-Series
Helps storage administrators and database administrators successfully deploy Microsoft SQL Server on NetApp EF-Series storage.
Helps storage administrators and database administrators successfully deploy Oracle on NetApp EF-Series storage.
Backup & Recovery
TR-4320: Best Practices with Commvault Data Platform V11
TR-4471: Best Practices with Veeam Backup and Replication
TR-4704: Deploying Veritas NetBackup with NetApp E-Series Storage
Describes the reference architecture and best practices when using NetApp E-Series storage in a Commvault Data Platform V11 environment.
Describes the reference architecture and best practices when using NetApp E-Series storage in a Veeam Backup & Replication 9.5 environment.
Describes the deployment of Veritas NetBackup on NetApp E-Series storage.
VSS
TR-4825: NetApp E-Series for Video Surveillance Best Practice Guide
TR-4818: Virtualizing Video Management Systems with NetApp E-Series Storage
TR-4848: Bosch Video Recording Solution with NetApp E-Series E2800 Disk Storage Array
Describes best practices for deploying E-Series arrays into video surveillance environments.
Describes how to design and deploy video management systems with NetApp E-Series storage.
Describes the video surveillance solution architecture and includes details of the components and storage best practices.
TR-4838: E2800 and E5700 with Milestone XProtect VMS Certification Report
TR-4771-DESIGN: NetApp E-Series and Genetec video management software
Describes the certification test results performed on NetApp E2800 and E5700 hybrid storage arrays.
Describes the certification results of Genetec Security Center Video Management Software (VMS) on the NetApp E2800 and E5700 hybrid storage arrays.
HPC
TR-4884: Entry-level HPC systems with NetApp E-Series and IBM Spectrum Scale
TR-4859: Deploying IBM Spectrum Scale with NetApp E-Series Storage
TR-4856: BeeGFS High Availability with E-Series using Red Hat Enterprise Linux Server
Describes the reference architecture for entry-level HPC systems based on NetApp E-Series storage systems and IBM Spectrum Scale.
Describes the process of deploying a full parallel file system solution based on IBM’s Spectrum Scale software stack.
Describes the required configurations for implementing high availability in a BeeGFS architecture backed by the NetApp E-Series system and using RedHat Enterprise Linux for BeeGFS storage, metadata and management services.
TR-4862: BeeGFS High Availability with E-Series using SUSE Linux Enterprise Server
Describes the required configurations for implementing high availability in a BeeGFS architecture backed by the NetApp E-Series system and using SUSE Linux Enterprise Server for BeeGFS storage, metadata, and management services.
