HCI
1.10
Compute Firmware Bundle 2.76 Release Notes
Contributors netapp-pcarriga
The downloadable compute firmware bundle contains the latest BIOS and BMC feature enhancements, bugfixes, and hardware support for all supported NetApp HCI compute nodes.
What's New
Version 2.76 contains general bugfixes.
Updated firmware components
This firmware package contains the following firmware versions for hardware components, with updated versions in bold:
Component H300E, H500E, H700E H410C H610C H615C
BIOS
NA2.1
NATP3.9
3B03
3B08.CO
BMC
6.84.00
6.71.18
4.00.07
4.68.07
NIC / Mellanox
14.25.1020
14.25.1020
14.25.1020
14.24.1000
Changes in firmware components
Here are the details of the improvements and changes included in each new firmware component:
Node and firmware component Improvements and changes
NATP3.9
  • CSESF-284 Tatooine + BMC 6.71.18 does not report when PPR function work success event.
  • CSESF-289 NA3.7 BIOS does not have the ability to report a success on hPPR (hard PPR).
  • Updated SKX ucode to 0x6906 and CLX ucode to 0x2F01.
Mellanox NIC firmware driver compatibility
The updated Mellanox firmware versions 14.25.1020 and 14.24.1000 are compatible only with the following versions of the VMware ESXi driver:
  • ESXi 7.0: H300E/H500E/H700E/H410C: Version 4.19.16.1
  • ESXi 7.0: H610C/H615C: Version 4.17.15.16
  • ESXi 6.7: Version 4.17.15.16
  • ESXi 6.5: Version 4.16.13.5
Note Before upgrading to version 2.76, make sure you check the current ESXi driver version. If the driver is out of date, upgrade the driver first. Then upgrade the compute firmware to version 2.76 for your compute nodes. Visit Update compute node drivers for instructions on updating your compute node drivers, which include the ESXi driver.
While NetApp Deployment Engine 1.8P1 does not deploy ESXi version 7.0, ESXi 7.0 is supported as a self-install or manual upgrade option. When you manually install or upgrade host OSes, NetApp cannot control the drivers and firmware for these OSes.
Download Compute Firmware Bundle 2.76
To download the Compute Firmware Bundle, go to the NetApp HCI Compute Firmware Bundle page.
Visit Update compute node firmware for instructions on updating your compute node firmware.
Resolved security vulnerabilities
The following are security vulnerabilities that have been resolved in this release:
  • CVE2020-0548, CVE2020-0549
  • CVE2019-11157, CVE2019-14607
Resolved and known issues
See the Bugs Online tool for details of issues that have been resolved and for any new issues.
Accessing the BOL tool
  1. Navigate to the BOL tool and select Element Software from the drop-down list:
    Storage firmware bundle release notes
  2. In the keyword search field, type “Compute Firmware Bundle” and click New Search:
  3. A list of resolved or open bugs is displayed. You can further refine the results as shown:
Find more information
