Uninstalling a Remote Acquisition Unit
PDF of this doc site
- Configuration and administration
- Data Warehouse administration
Creating your file...
Your file is ready
You can uninstall a Remote Acquisition Unit when you no longer need it.
It is strongly recommended to back up the vault before uninstalling OnCommand Insight. See the SecurityAdmin Tool instructions for more information. |
Steps
Log in to the Remote Acquisition Unit server using an account with sudo privileges.
Ensure that any OnCommand Insight windows are closed.
You can view syntax, command arguments, and parameter usage for
uninstall.sh
by entering the following command:sudo /usr/bin/oci-uninstall.sh --help
Type the following command:
The uninstall script runs. Follow any prompts.
