Add Annotation Rule dialog box
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
The Add Annotation Rule dialog box enables you to create annotation rules in Unified Manager to dynamically annotate storage objects.
You must have the OnCommand Administrator or Storage Administrator role.
Name
Specifies the name of the annotation rule.
Target Object Type
Specifies the type of storage objects (storage virtual machines (SVMs), volumes, or clusters) that you want to annotate.
Apply Annotation
Specifies the annotation and the value you can use to annotate storage objects when all conditions are met.
Conditions
Specifies conditions that determine which storage objects you can annotate.
Command buttons
Save and Add
Adds the annotation rule you created and enables you to add another annotation rule without closing the dialog box.
Add
Adds the annotation rule and closes the Add Annotation Rule dialog box.
Cancel
Cancels the changes and closes the Add Annotation Rule dialog box.
Add Condition
Adds a condition to define the annotation rule.
Add Condition Group
Adds a condition group to define conditions for the annotation rule.
