Annotate Volume dialog box
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
Your file is ready
The Annotate Volume dialog box enables you to manually annotate storage objects. You can select either a single volume or multiple volumes and annotate with a specific value pair from the existing list of annotations.
You must have the OnCommand Administrator or Storage Administrator role.
Annotation=Value Pairs
Enables you to select the required annotation for the selected volume.
Apply
Applies the selected annotation to the volume.
Cancel
Closes the Annotate Volume dialog box without saving your changes.
