MBps performance counter charts
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
The Performance Explorer MBps counter charts display the number of megabytes of data transferred to and from the selected object per second.
The popup window that is displayed when your cursor is in the chart area shows the specific counter values at specific times.
When displayed in Zoom view, the volume and LUN charts also display Quality of Service (QoS) maximum MBps throughput threshold settings, if configured in ONTAP.
When viewing a volume or LUN that is sharing the MBps of a shared QoS policy, a line for “Total Workload MBps” is displayed to show the MBps that are being used by all other workloads sharing this policy.
The bottom of the chart page displays information for the minimum, maximum, average, and 95th percentile MBps for the selected time range.
There are two types of MBps charts available:
MBps - Total counter chart
Displays the number of megabytes of data transferred to and from the selected object per second.
MBps - Breakdown counter chart
Displays the same MBps data separated into disk read, Flash Cache read, write, and other operations.
This chart option applies when the selected object is an SVM, node, aggregate, volume, or LUN.
Flash Cache data is displayed only for nodes, and only when a Flash Cache module is installed in the node. |
Zoom View button
Displays a magnified view of the counter chart data.
Events
The occurrence of critical, error, warning, and informational events are indicated on the time lines above the charts.
Thresholds
The dashed, horizontal line indicates the utilization warning threshold value set in Unified Manager.
The solid red line indicates the utilization critical threshold value set in Unified Manager.
Counters
The counters in the left pane show which counter values are being displayed. Deselecting or selecting the that is associated with a counter hides and shows that counter information from the chart and can help when comparing object MBps.
