OnCommand Unified Manager 9.5
Configuration/Health Thresholds page for Qtrees
Contributors netapp-adityaw
The Configuration/Health Thresholds page for Qtrees enables you to configure global health threshold values for monitored qtrees. Events are generated for a qtree only when a Qtree quota or a Default quota has been set on the qtree. Events are not generated if the space defined in a User quota or Group quota has exceeded the threshold.
You must have the OnCommand Administrator or Storage Administrator role.
Events are generated when a threshold is breached. You can take corrective actions for such events.
Capacity area
The Capacity area enables you to set the following qtree capacity threshold conditions.
  • Space Nearly Full
    Specifies the percentage at which a qtree is considered to be nearly full:
    • Default value: 80 percent
      The value for this threshold must be lower than the value for the Qtree Full threshold.
    • Event generated: Qtree Nearly Full
    • Event severity: Warning
  • Space Full
    Specifies the percentage at which a qtree is considered full:
    • Default value: 90 percent
    • Event generated: Qtree Full
    • Event severity: Error
Command buttons
  • Restore to Factory Defaults
    Enables you to restore the configuration settings to the factory default values.
  • Save
    Saves the configuration settings for the selected option.
