ONTAP 7-Mode Transition
Considerations for transitioning of 7-Mode SnapLock options
The 7-Mode Transition Tool supports the transition of a few 7-Mode options that are related to SnapLock volumes.
Data ONTAP operating in 7-Mode has the following options that are related to SnapLock volumes:
  • snaplock.autocommit_period
    This option is at a volume level in ONTAP, and is transitioned to ONTAP during the transition.
  • snaplock.compliance.write_verify
    This option is not applicable in ONTAP.
  • snaplock.log.default_retention
  • snaplock.log.maximum_size
Although the snaplock.log.default_retention and snaplock.log.maximum_size options are supported in ONTAP, the settings configured in these options are not transitioned by the 7-Mode Transition Tool. You must manually set these options for audit volumes after the transition is completed.
