ONTAP 7-Mode Transition
Preparing for copy-based transition
Before initiating a data copy operation from 7-Mode to ONTAP, you must understand the requirements and restrictions for migration, and complete certain tasks on the 7-Mode system and the cluster.
You must ensure that the following requirements are met before transition:
  • The 7-Mode and ONTAP systems must be reachable from the host on which the tool is installed.
  • The 7-Mode systems must be running the supported Data ONTAP versions.
  • SnapMirror must be licensed on the 7-Mode system.
  • Required feature licenses, if they exist on the 7-Mode system, must be installed on the cluster.
  • The NTP server must be configured and the time must be synchronized across the 7-Mode system and cluster.
  • All preparatory tasks on the 7-Mode system must be completed.
  • All preparatory tasks on the cluster must be completed.
Related information
