ONTAP 7-Mode Transition
Cannot select a secondary volume from the Volume selection pane
You cannot select a secondary volume from the Volume selection pane and transition it as a volume SnapMirror relationship if the volume is not online or if the SnapMirror relationship is broken.
Workaround
Use the ONTAP command-line to perform either of the following workarounds:
  • Bring the secondary volume online if it is offline.
  • Fix the SnapMirror relationship if it is broken.
