Compression is not enabled after transition from Data ONTAP 7.3.x
PDF of this doc site
- Copy-based transition
- Copy-free transition
Creating your file...
Your file is ready
If you transition a 32-bit volume on a system running Data ONTAP 7.3.x to an ONTAP volume that is in a 64-bit aggregate, compression is not enabled on the ONTAP volume after the transition. Compression cannot be enabled until the volume is upgraded from 32-bit to 64-bit.
Workaround
Wait for the upgrade to finish.
You can use the
volume show -fields block-type -volume vol_name
command to verify that the block type of the volume changes to 64-bit. -
Enable compression by using the
volume efficiency modify
command.
