ONTAP 7-Mode Transition
Assessing controllers and hosts
You can collect and assess information about the controllers and hosts by using either the 7-Mode Transition Tool or the Inventory Collect Tool, depending on the security regulations in your environment.
  • The 7-Mode Transition Tool collects inventory information about controller and hosts by adding the systems or by using the inventory report generated by the Inventory Collect Tool.
    The 7-Mode Transition Tool then assesses inventory information and creates the transition assessment report.
  • You must be aware of the following considerations when performing transition assessment:
    • You should not perform both assessment and migration operations simultaneously on a controller.
    • You should avoid performing assessment operations on active storage controllers during peak hours.
