ONTAP 7-Mode Transition
Deleting a project
If you do not want a project, you can delete it from the Dashboard.
  1. From the DashboardProjects Groups pane, click the project group to which the project belongs.
  2. From the Group Summary pane, click Modify, and then click Delete.
    You cannot delete a project if the project has failed during the cutover stage.
