ONTAP 7-Mode Transition
Generating an FC zone plan
For FC switches, you must generate an FC zone plan as part of the transition assessment report to configure the zones for grouping the initiator hosts and targets after the migration.
  • The 7-Mode system, hosts, and the cluster must be connected to the same switch.
  • You must have created the required target SVMs and FC LIFs on the cluster.
  • The FC LIFs that are created on the target SVMs will have WWPN, which are different from 7-Mode WWPNs. Therefore, perform FC zoning while you transition SAN for FCP.
Steps
  1. In the Collect and Assess section, click Add Systems.
  2. In the Add System window, perform one of the following actions:
    • Add a single system:
      1. Enter the FQDN or IP address of the system.
      2. Enter the user name and password for the specified system.
      3. Select the system type:
        • Data ONTAP storage systems
        • Hosts: Microsoft Windows, Red Hat Linux Enterprise, and VMware ESXi
        • FC switches: Cisco and Brocade
    • Add multiple systems by clicking Browse, and then selecting the text file that contains the credentials for multiple systems.
  3. Click Add.
    If the assessment status of a system is Ready, then you can perform transition assessment for that system.
  4. Generate the transition assessment report with the FC zone plan:
    1. Select the systems, including the required FC switches, for transition assessment.
    2. Click Create Transition Assessment Report.
    3. In the pair systems and start FC zone planner dialog box, select the 7-Mode systems (single controller or HA pair), the switch connected to the cluster, and an SVM in the cluster.
    4. Click FC Zoning for paired systems.
    5. In the Create Transition Assessment Report dialog box, select the Data ONTAP version of the target cluster.
    6. Specify a prefix for the file name of the reports.
    7. Click Generate Report.
The FC zone plan is generated as a .zip file. The plan contains zones created per the igroup configurations on the 7-Mode systems. Each zone contains a single initiator WWPN and multiple SVM target WWPNs.
You must use the FC zone plan for configuring the zones to group the initiator hosts and targets for providing data access from the cluster.
